Though I’d start a separate thread if somebody else is having similar issues. Keep getting bans from rtk2go intermittently, and as I understand it’s due to RTKBase continuing to cast even though there’s nothing coming in from the F9P. So am I reading the logs correctly:
Here it’s losing connection to F9P as bps drops to zero. Keeps running like this forever and eventually rtk2go gets banned because sending no data…
Jan 11 12:30:57 basegnss systemd-journald[143]: Suppressed 11 messages from str2str_tcp.service
Jan 11 12:30:57 basegnss run_cast.sh[473]: 2022/01/11 11:31:15 [CC—] 88865480 B 45547 bps (0) /dev/ttyACM0 (1) 3 clients
Jan 11 12:31:57 basegnss systemd-journald[143]: Suppressed 11 messages from str2str_tcp.service
Jan 11 12:31:57 basegnss run_cast.sh[473]: 2022/01/11 11:32:15 [CC—] 89195632 B 44369 bps (0) /dev/ttyACM0 (1) 3 clients
Jan 11 12:32:57 basegnss systemd-journald[143]: Suppressed 11 messages from str2str_tcp.service
Jan 11 12:32:57 basegnss run_cast.sh[473]: 2022/01/11 11:33:15 [CC—] 89310348 B 0 bps (0) /dev/ttyACM0 (1) 127.0.0.1
Jan 11 12:33:57 basegnss systemd-journald[143]: Suppressed 11 messages from str2str_tcp.service
Jan 11 12:33:57 basegnss run_cast.sh[473]: 2022/01/11 11:34:15 [CC—] 89310348 B 0 bps (0) /dev/ttyACM0 (1) 127.0.0.1
Jan 11 12:34:57 basegnss systemd-journald[143]: Suppressed 11 messages from str2str_tcp.service
And when trying to restart main service, that fails:
Jan 11 12:42:25 basegnss systemd[1]: Stopping RTKBase Tcp…
Jan 11 12:42:25 basegnss systemd[1]: str2str_tcp.service: Succeeded.
Jan 11 12:42:25 basegnss systemd[1]: Stopped RTKBase Tcp.
Jan 11 12:42:36 basegnss systemd[1]: Starting RTKBase Tcp…
Jan 11 12:42:36 basegnss systemd[1]: Started RTKBase Tcp.
Jan 11 12:42:36 basegnss systemd[1]: str2str_tcp.service: Main process exited, code=exited, status=255/EXCEPTION
Jan 11 12:42:36 basegnss systemd[1]: str2str_tcp.service: Failed with result ‘exit-code’.
Front page looks like:
After reboot it works as normal once again.
Any ideas? Am I correct in thinking the problem is in the connection between RasPi and F9P? Maybe a bad USB cable? Install is the latest 2.3.1 pre-built image, just added a perl script running in the background updating the DNS records.
