Hi,
Im looking for the same in the Fendt One 209.
Stop the tractor while driving by pressing the FR switch forward, find also the CAN message with the Peak View, but would like stop the tractor by a Trimble Remote output pulse…
Hi,
Did you get any futher with this?
The FendtOne has a lot going on, there is multiple messages related to the same thing but only one will actually control it.
Total guess but you can try this:
18FF12A7,E9,8F,FE,E8,8F,FE,E0,FF
Send once to toggle the “N” button, the joystick will hopefully be sending that message with E8 at the start, so bang the E9 message out in between and it should be none the wiser
I had cataloged all addresses that were active when the flipper is pushed forward, but none of them worked when i send them to the canbus, not sure if this one above could work, i’ll try it out.
In my case i need an ‘active stop’ , when the tractor is driving and you push the F/W flipper forward, it goes into active stop. when you release it again ,it starts driving again. I thought that this would have been easy to do, as i’ve managed to do anything else by sending the commando’s to the canbus.
But this problem i never got fixed. I think , and it seems , that the F/W flipper constantly (at 10Hz) sends out a N signal on the can bus, making it impossible to get a FW signal in between while the N signal keeps beeing in the way.
I’m sure there are other ways to stop and start driving this tractor (Fendt 211 S4) , but right now i didn’t have any luck so far.
I bought a module from Risseeuw in the Netherlands, i connect that to the K bus amd the ISOBUS en the power suply from the FNR switch.
With that module its possible to make an active stop, like the you want, works fine!
thanks !
Bonjour a tous, je cherche a utiliser un bouton pour mon nouveau fendt 600 avez-vous trouvé une solution pour l’utiliser?
Can you be more specifick ? What button?
Perhaps the small Go for engage autosteer
