Field boundary is moving issue
right, summarise so far
i was getting issues with field boundaries moving over time on my own base station.
changed it from survey to fixed mode back in the spring :man_facepalming:
so ok all my boundaries then were wrong but as and when i went into a field i was deleting and redoing them.
did a few fields a few weeks ago and back into them yesterday and the actual boundaries had shifted by approx 4.5m south and 1.5 west.
base is f9p ntrip wifi master.
cant remeber tractor agopen spec but i hope @TeddyStamford will tell you :crossed_fingers: running version 6 something
base or tractor issue??
i think base but? :man_shrugging:
is there a way to “reset” boundary position in agopen ?
thanks
dave
Are you absolutely sure you had RTK fix at both times, the difference i meter fit with and without RTK fix on different days.
Yes positive had rtk fix
Are you sure you’ve saved Fixed mode on the F9P, I think that’s the most likely problem.
Willc heck later
Base station issue
Drove an north/south AB line then restarted the base station
Track shifted 115cm west🤦‍♂️
How is this done in Stefal’s rtkbase? I recently set up mine and not sure if I have seen these options…
You don’t need to worry about that in Stefal’s RTKbase. It will use whatever fixed coordinates you entered into the GUI.
How to configure simpleRTK2B as static base station - ArduSimple
will do this again later
