I started using AGOPENGPS using a win10 Notebook, connected an F9P via USB (connection is fine) and NTRIP. Signal is fine, no failure is shown.
I recorded the boundary of a field. The field is rectangular, but the recorded boundary of the field looks not rectangular. See picture below.
Does anyone have an idea why this happens?
The standard position is at Brian’s place in Canada. To avoid this problem set simulator position to your place, (just within some kilometres is OK)
Then this problem does not occur even if field is created when SIM is on.
As Davidwedel and Larsvest described the problem occurs when you start to create the field in SIM Mode and then go to the field.
So just enter your coords in SIM (maybe thats not even neccesary) and start creating the field when you are near the field. Then it works as it should.
