Fixed position is overriden by survey in?
I have used PPP to establish more accurate coordinates for my base station. So in U-center Message view under TMODE3 I have entered “Fixed mode” and my coordinates - instead of “Survey in”.
But when I log the data from the base station I see this message in the log:
20:02:42 R → UBX NAV-SVIN, Size 48, ‘Survey-in’.
Does this mean that my fixed coordinates are not being used?
Any suggestions and thoughts are appreciated!
Did you save to Non-Volatile memory when you were done? If you didn’t, the settings will reset when the base powers off/back on. You can go and check if “Fixed Mode” is still set.
(screenshot is from configuring the zed f9p · AgHardware/Boards Wiki · GitHub but that is concerned with configuring the rovers. But saving is still relevant!). If “Fixed Mode” is still set, I would just wait until something actually went wrong in the field before I worried too much!
Yes I did that. I noticed that most of the changes I made did not percist. I now tried to upload a new config file, and now it seems to be working. Though it sends the same survey in message, it reads my PPP coordinates in RTK2GO…
