The flowmeter has several testmodes. I’ve been running Test Frequency, and set the desired Hz for test. Nothing happened. (But voltage got lower with higher Hz.)
There is a nother selection too : Test pulse output.
Hitting ok to trigger pulses, the quantity applied increases.
Maybe good enough to get hands dirty for real now.
But would be nice with some comments on the Pulse output settings in flowmeter.
Looks like the sensor has a sinking connection. It sinks the signal when connected to the pcb. RC15 expects a sourcing sensor. It also has 4/20 and modbus. This could work with the RC15 but would require firmware changes. RC11-2 or the RC12-3 would work since they use a sinking connection.
Tried analog, but no luck.
Long story short : Got an idea to let 8266 read the flow. That worked well.
Then had ClaudeCODE scan the RateControl repo and produce an .ino to simulate flow.
Worked well, then merged the two and have a working setup. And a spare RC15
