Just got a FZ-G1 mounted. I was hoping to charge via USB, and I thought I found in the FZ-G1 specs that it was possible.
However, no luck. I really hate the thought of having an inverter to charge the thing: DC to AC to DC. I thought I was going to have a slick setup with a cheap Amazon 65W USB charger, but looks like that’s not going to work as planned.
I happened to do a test yesterday and found out that you need at least 12.9 volts. so that it actually charges. Usually the tractor achieves this, but I don’t know if this is the case with all of them
I had a 12v charger running through the cigarette plug which was a nightmare to route the cable to the tablet. So before i cut the plug off i stripped the wire protector back to see which one was positive and negative. I then wired it straight into the main master switch i use for turning the pcb on and off. Put a fuse in the line and seems to work ok
