FZ-g1 Screen jumping around
My Setup
FZ-g1 connected to F9p connected to aerial. Using USB-A port on tablet and USB C on F9p.
Purchased this kit from Ardusimple 2023. simpleRTK2B Basic Starter Kit IP67 - ZED-F9P Evaluation kit (ardusimple.com)
I use Agopengps to paint the screen as i go up and down field, no autosteer.
I was doing some spraying yesterday evening with our MF168 and agopengps, 7km h.
The FZ-G1 tablet developed a mind of its own, all of a sudden it began changing the size of the agopengps window from full screen to default size and back again. It then decided to just display half the Agopengps window on the screen, then change, then jump back… More a windows tablet problem than Agopengps.
Shut down and startup didn’t do anything.
ever seen anything like that
Tablet mounted directly to the cab and there is vibration in the cab framework.
Was it possible the vibration from cab framework would be triggering the tablet accelerometer and causing the window to jump around. or the screen stuck or something.
Tried it while driving around in the car yesterday evening and no issue. Tablet seemed to be fine while tractor was stationary in the yard at idle, only in the field all these problems appeared.
Had sprayed the same field 1st Aug with same tractor. Temperature was 25C rather than 12C and the vibration characteristics may be different.
I would try enabling Kiosk Mode in AOG. In the hamburger menu in the top left corner. It locks AOG to full screen.
I had a similar problem. I had to disable mouse. I think it was confusing gps with a mouse and was randomly clicking all over the screen.
See this comment for how to fix it: Toughpad/book - #127 by andi
will try that, did you have to use the stylus then when you wanted to click something on the screen.
Should also add it only happens in a tractor whose cab has high vibration.
Never happens when i put tablet on the seat of the car and drive around.
i dont have kiosk mode in my AOG
Oh you must be running an older version. Was added in 6.2 I think.
I do everything with my finger on the touchscreen, but the stylus would probably work too.
