FZ-G1 USB dropping off after some time
I have a Panasonic FZ-G1 connected directly to the Ardusimple RTK2B via USB. See photo attached. I am using this for lightbar guidance. No need for Auto Steer just yet. I can get RTK with this arrangment. I have the updated firmware on the aerial.
USB to Serial Driver installed on Panasonic FZ-G1: FTDI 2.12.36.4. This is the most up to date version, reinstalled too to rule it out.
AgOpenGps runs v well.
Rather Annoying Problem which occurs
The USB port on the Panasonic FZ-G1 can drop off periodically and can be difficult to restart. USB drops off at random. Can be 2hrs or could be every 10mins. I don’t think it’s the USB cable plug in connection to the tablet, as I don’t hear that sound associated with plugging in and out cables.
It could take 4-5 attempts to restart AgIO before I can get back up and running.
Any ideas what could be wrong
Windows may be putting the USB port to sleep. There is a setting in device manager to tell Windows not to put the USB port to sleep. I don’t recall the exact menu path to the setting but Google for it and there should be many hits with instructions.
Yes i am aware of this,
USB suspend timeout setting in Device manager
I have that setting turned off which cuts power to a device if its not active for a period of time.
Have you tried a different USB cable or port?
I have tried a different cable but doesn’t make any difference.
I only have one USB port
The reason AOG turned toward UDP, was the problems with USB. A couple of years ago, the talk was about grounding issues, and power supply issues. As example we found that it is not a good idea to power the tablet from cigarette lighter plug and at same time power the PCB, with + and - direct from battery.
So first make sure GND is at same spot, and power comes from same cable.
In this case the F9P is being powered by the tablet and I think that’s all that’s connected other then possibly a charger. If you’re using a charger, could try unplugging it.
charger doesn’t make any difference, didn’t have it connected on Sunday last, when i was using it
I read through all that about grounding but I dont think it applies to me. Per my photo above where I show my setup, all I have is the aerial and the F9p.
Is there a way of figuring out what is actually dropping off, from Windows event lot or maybe another tool.
I guess im trying to figure out is it a driver problem or is it a loose cable issue or maybe something else.
I do not know if a program can do that, but you could start with supplying the F9P from another power source too. I do not know the specifications for your computers abilities to supply usb power, but many computers can’t supply more than 0.5 A out (at 5V that gives 2500 mW), and f9p use 600 mW. Should not be a problem for your computer, but maybe ??USB charger FAQs | CMD
@aidank Can you power the F9P with something else?
It would probably be a good idea to keep all of your troubleshooting / help in one thread. Probably this one.
You posted about this in two other very old threads ( 1 - 2 years old ) and some folks are trying to help in those threads.
Have you tested the components in isolation? Run the F9 on another PC running the same version of Windows / AOG.
Do you get the same behaviour if you use uCenter to log F9 data.
Only time I see it happening is in the field when actually working on the tractor, never seen it happen when at my desk exploring it or never seen it happen driving around the road in the car.
Did you check if wiggling usb cable breaks the connection? try zip tie or smth to secure movement of the connector.
Sounds like a worn usb port. Try a different laptop
In the field, some vibration, heat, dust, voltage spikes, inteferences and so on, a perfect situation for short drops. I had it once and changed my setup to ethernet afterwards (Why spending so much time in solving USB stuff, better go for udp)
Some people want an Android version. How should that communicate? Wifi?
I don’t believe an Android client is on the roadmap. Happy to be corrected. Significant experience has led to UDP over ethernet as the preferred connection method. If you want to take on the headaches of porting to Android I’m sure it would be appreciated, you could then chose your preferred connection methodology but be aware most AgIO hardware is built for UDP over Ethernet so you would also need to work that out also.
Maybe better suited to it;s own thread ?
