Hello, I am not yet an active user of the AgOpenGPS system, but before purchasing I would like to check certain things, if this system also allows them. I do not need an exact explanation of how this can be done, but only if it is 100% feasible, so that I can decide on this product more easily. This information is very important to me because of the organization itself, which would save me a lot of time.
We are producing approximately 150,000 grapevine nursery plants each year.
Our workflow is different from typical row-crop farming, so I would like to know if AgOpenGPS already supports the following workflow.
Field layout
- Row spacing (center-center): 1100 mm
- 9 rows per block
- 3 m tractor lane
- Rows are perfectly straight (200–300 m long)
A1 A2 A3 A4 A5 A6 A7 A8 A9 <- 3 m tractor lane -> B1 B2 B3 B4 B5 B6 B7 B8 B9
1. Permanent guidance lines
Can I create all AB lines once during mulch laying and reuse exactly the same lines weeks later for:
- Weeding
- Trimming
- Spraying
- Harvesting
without creating new AB lines?
The tractor should always drive on the same RTK line .
2. Driving sequence
Normally operators drive:
A1
A2
A3
We would like to work like this:
A1 → B1 → A2 → B2 → A3 → B3 ...
Reason:
Two tractors work together.
- Tractor 1 = rotary harrow
- Tractor 2 = mulch layer
With this sequence both tractors continuously circulate and never have to wait for each other at the headland.
Is this workflow possible in AgOpenGPS?
3. Fixed Start and End lines
Every row should start and end at exactly the same GPS position.
Example:
START LINE
300.00 m
END LINE
Questions:
- Can AgOpenGPS define a fixed Start Line ?
- Can AgOpenGPS define a fixed End Line ?
- Can it display the distance to Start/End?
- Can it warn the operator exactly when to start and stop the implement?
Goal:
Every row should be exactly 300.00 m long.
4. Saved field project
Can one field permanently store:
- AB lines
- Row spacing (1100 mm)
- Number of rows
- Tractor lanes
- Start/End lines
so that next time I simply open the same field and continue working on exactly the same guidance lines?
Thank you very much.
I believe this workflow could also be useful for vineyards, orchards and other perennial crops where the same RTK guidance lines are reused throughout the entire season.
