Go to the github boards
Remember to school down, schematics consist of several pages.
Are you able to use a speed cable for auto kg/kph with Agopengps?
Also if you have the hydraulic steering block does it turn off when you grab the wheel and turn?
Thank you.
Yes the baraki hydraulic valve does disengage the steering then the wheel is grabbed
Thank you for the reply
Hello, i have one problem, acs712 can it go directly to teensy or it needs pullup resistor?I cant find scheme anyware.
