I hooked up all Gps and try to turn on the simulator and it says that it is forced off because the Gps is hooked up what am i doing wrong.
You must disconnect GPS port (physically )before turning on simulator. If you were using virtual port , you must connect some other available com port temporarily (disconnect that and select simulator).
