I don’t know how you are powering it but it could be ac noise from the alternator messing with it. Try isolating it from the tractor electrical system and see if that helps
What I would do is try to power it some other way and see if that fixes it. Or just see if it ever happens with the engine off. If it still does start wiggling connections starting with the gps antenna and see if you can cause it to happen.
