Hi, I’m looking for some help configuring the adusimple f9p board i have in the tractor. I have uploaded the latest firmware onto the board and uploaded the the configuration file. Everything is responsive when I am on simulator mode however when I connect gps I find that the reactiveness of the roll is really slow and the steer enable button and was is too. The speed reading on agopengps is also far to high.
What can i do to fix this?
Make sure the configuration file was also sent, and saved? Sounds like 1hz rather than 10…
Thanks i think i must have been using the wrong configuration file. I have since found the right one and all is working well.
