Honeywell RTY/RTP Series datasheet Question
I am building a wheel angle sensor based on the RTY/RTP honeywell sensor and I have a question about direction of rotation and output. If you rotated the input shaft or magnet clockwise would the output go high or low(from the perspective of the photo below)?
sensor
datasheet
I guess this depends if you buy one with standard output or with inverted output. Clockwise rotation with standard output, it should go high.
That is also how I read the data sheet too. On a standard output sensor a clockwise rotation would produce the higher 4.5 voltage output. It appears that the drawing and the photo of the actual sensor show the sensor in approximately the same position. I wanted to double check with someone else before I order the sensor. I’m not sure I would be able to return it very easy if I get the wrong one.
Edit: I brought the standard model and can confirm that the above information is correct if anyone references this post in the future.
