Has anyone attached a phidgets motor to the steering column of a new model JD? I have a phidgets 24v motor that im trying to attach to the steering column of a 2021 6155M but the plastic box with the reverser and indicator is quite bulbous (can’t fit potato farmer’s universal kit). The column also has a plastic sleeve the whole way down (not pictured).
Anyone done a similar tractor or has got any ideas?
so take out that bearing and replace it with a clamp? and then put pressure on the bulbous box for antitorque? ill check it out in the morning
thanks for the suggestion!
Valves on a 6175R I looked at recently are under the throttle-side of the cab, might be covered by a plate. Come up from underneath the tractor, you’re looking for the FEMA valves there.
588-40F15RE (lock)
807-DC780R-564K (left / right so get 2)
As for the AIO PCB:
I had to remove the C3 from the pressure sense line.
Also the voltage divider better be 2k / 4k or smaller instead of the 6 / 12k for it to work properly.
In terms of code:
