I think we can talk about this function.
What do you mean? Hooking up with an RTK A-B Line?
There is recorded path function and you can name/save different paths for different implements, for 3 point attachment implements you can reuse same paths.
Main problem with using autosteer for this is that machines are often stored in roofed areas where you cant get RTK fix or even GPS.
Yes, and I think hooking up with Autosteer is just unnecessary. Not worth the development time, you’re done hooking up your three point (if you can handle a tractor) before Windows/Agopengps even started.
Yes,I’m too poor to hang up farm tools.I am a new farmer.
