Tring to find a way to accurately work out counts per degree, seen that there was previously a steering wizard as part of AOG. What happend to that?
The thing is that accurate measured counts per degree are not always right… sometimes it works better with a few more clicks or less. First be sure to have a sort of good was zero. Then turn your wheels to say 45 degrees and move the cnts per degree to a value that AoG see about 45 degree in the steer Config window. When driving sometimes a few click higher or lower can make it help more accurate or less bumpy
I was thinking of drawing a right angle triangle out and working out the angle and pointing my wheels in that direction to get an accurate measurement of the wheel angle… but now i think i was over complicating things!
Good idea!
*but not necessary.
