I have been trying to set up Headland Hydraulic lift and have it drive relay etc. I struggled to send settings from AOG to the arduino and after much frustration worked out that it only updates from AOG to the arduino if a field is closed.
Is it desgned this way or is it a bug? I would think you should be able to update raise lower times etc whist in the field to fine tune. V5.5
Thanks again to all involved and the work that has gone into this.
