Hydac hydraulic valve for AgOpenGPS
Does the steering part also have high flow?
Would be the same as a Case IH steiger 9180-9380, 60L might do it?
The valves are 60L and when you order with a 26L prop valve it will work.
Hydac_GPS_Ventil_Erklärung_DE.pdf (213,5 KB)
Hydac_GPS_Valve_Explanation_EN.pdf (213,5 KB)
Ventiel_uitleg_duidelijk_in_stappen.pdf (213,5 KB)
Due to private issues, we will stop selling hydac valves after the last batch in januari.
If anyone needs a valve, i advice you to looks at Navisklep.pl or check @CQuick valves.
Thank you for your understanding.
The orders that where placed between november and january will be handeld. After that we stop.
