I am trying to get hydraulic lift working on headlands/u turns. But AOG doesn’t send anything while looking at the module communication dialog. Is there more setup required some where?
Do you have a separate machine control module (box with relays and nano)?
No. I want to use my autosteer board. But the problem is aog is not sending any data out to anything. Do I have to set it up some where?
Right. Sorry for the hassle but I worked it out. You have to create a headland in the boundary dialogue, then turn it on, then turn on hyd lift also. Sounds obvious now, but it is not documented well that this is the process to get it to work.
