Finally had some success plumbing a hydraulic valve into my Open Centre LS orbital.
I’m using the Hydraforce SP10-57C with a 6/2 valve.
The 6/2 valve by default allows the orbital to connect to the steering ram but when powered up blocks flow between the orbital while allowing the hydraulic valve to flow to the ram.
I have the steering working when manually providing power to the solenoids.
I’m now in the midst of mounting everything neatly, both under the bonnet and inside the cab.
Have a question re power to the 6/2 solenoid. I have found a few threads but not being anything remotely like an electronics person can someone point me in the right direction?
How do I wire it in? What do I need? I’m using on old PCB (doesn’t have a version written on it, but I’ve had it over 12 months) with a Cytron motor driver installed.
Any help appreciated.
