I keep blowing the WAS
Has anyone else had this happen or have any tips?
Had what happen?
Wheel angle sensor blow for no apparent reason
Can you still be more specific? Do you mean burnt out or a bad connection or just stop working?
  • 5V stable?
  • Wiring ok (star connection - no loops!)?
  • Plugs ok?
  • Cable not broken? Not shorted or whatever?
  • Sensor cable does not follow high-current lines like starter or generator?
  • 5V supply current for WAS as specified in the manual?
If you can anwer all with “yes”, here are some hints to avoid this again:
  • Add a capacitor (e. g. 100µF) and a 5V1 suppressor diode near to the sensor (both between 5V and 0V - mind the polarity!!)
  • Add 2 Schottky diodes from the analog signal to both supply lines (again, mind the polarity of both!)
Just stop working
One thing I will say is I dont have any of the capacitors in the pcb could that cause damage?
None of the voltage regulator stabilization capacitors?!?
Maybe… But your setup is still a miracle to us, so focused help isn’t possible…
Yeah… hangs head
It worked for a year that way
Best thread ever!
