Image Planter
For those wondering if AOG will plant images, the answer is yes, with a hack. Still working the bugs out, but it is possible. It is planting where there is no green. I have the sections turned to red for contrasting colors. Planning and planting corn mazes is now possible.
Or planting you nations flag.
Or maybe your thing is crop circles:
Or in support of your favorite “President.”
Unbelievable!
@KentStuff small question did you try oposite way to catch one or more analog signal frome ADS or Analog port and make a color map according value sensor ?
I have before. Mapped color based on sprayer pressure.
Any chance to get again to add somme yield sensor or whatever sensor and make mapping ?
I’ll dig it back up and see if we can get it updated to the latest version. Each section took a reading from the arduino Pins 1,2,3 (I think) and the voltage was mapped based on the reading.
Reversed image? Yes, it will do that as well.
This was the image loaded in the background.
I m interesting if you can redo it
Do you want it in the autosteer board or the machine board?
Are you using a custom pgn to send pressure data? I’m doing that just for display purposes so far, I display section pressure instead of section number along the bottom. I’d like to try your mod. Which version of AoG do you mod?
I’ll mod the latest section control branch. Right now, busted the dish washer and have water all over the kitchen. So small delay in the AOG build.
This is very cool, if a guy had a tiny air seeder with section control on every tip. Put blue grass in one tank, and rye grass in the second tank.
Print Plant semi permanent pictures in lawns.
Hello thanks Kentstuff
basically i would like to say both
As argument machine board is better
Also in Agopen GPS if the menu can indicate a small calculation to adopt a rules according the sensor and some relation with the speed or not to do the color range
Let’s debate
regards
I almost made all the changes last night. But running a test run, I must have changed something I should not have. The sections were hard to turn on, an once they were on, they would not shut off. Couldn’t find the mistake. Starting over.
I am putting it in the autosteer board first. I believe you will need to pick where to pull the data from. I’ll start with a range of values, then work on settings.
Thanks a lot
sorry yesterday i sleep
Kent…I just stumbled across this thread. It’s exactly what I am trying to achieve…use AgOpenGPS to plant a corn maze. I am very new (only installed the software today) so are there any tutorials on how to achieve the image mapping to GPS co-ordinates? The post seems to indicate that you are using teh image map/GPS to have the planter only plant in designated zones? This obviously means modifications to the planter to accept commands from AgOPenGPS? Any guidance (pun intended!) would be most helpful.
This was exactly what we built the hack for.
How do we go about doing this? You can just use a normal existing section control module and not have to do anything special on the machine side, right? How do we get the image into AOG?
You are correct. It is just normal section control. I originally placed a green image on the back screen. But later moved it to the main screen. It was on the github page for a long time. I will find it again an repost. It is a few versions old.
@KentStuff any luck finding that old post? I was able to create a multikml file with the boundary of the field and the maze itself as one contigous polygon. But that doesn’t seem to help. Basically within the main field boundary (i.e. where the tractor is sitting right now) i want to plant. Within the “inner boundary” is the maze and I don’t want planted. We can import the image as the “map/field” background and then tell it to plant by colour contrast? This is how you achieved it?
I did not get a chance to find it yet. But I did see on the other post someone kept a link to the program. That will help me find it in the archives.
