Field and vehicle data misspelling, AGOPEN creates an AGOPENgps folder in one of the fields folder, then nests another folder in the field’s collection folder, and so on. Saved fields will not be opened the next time the program is started because the path to them is wrong.
Now the question is where did it come from and how can it be fixed?
I uninstalled AGOpen, moved the fields to another directory and deleted the AGOpen folder in my documents.
I also deleted the AGOpen folder in APPdata.
It did not work, after reinstalling in the folder my documents have the path as in the attached sket.
Hello ,
To change the path to the files.
In the first menu at the top left.- “directories” under “language”.
Hoping to understand your request.
Thanks. I needed this, but I missed this option.
