Hello. I just installed AOG in a tractor. It’s my first time setting up an RTK base station also. I’m just wondering what the different ways are to determine if the system is recieving RTK corretions, in the AOG GUI?
There is a message LOST RTK
And if I can’t see it I have RTK?..
Where can this message be seen?
Should say RTK fix or Float, in upper left corner of main screen
In Agio press the big arrow in the top right, opens a side bar that shows the rtcm3 count.
The left arrow is what @Ebedel is talking about. The age should be between .1 and 5, and it should say RTK Fix, or RTK Float. DGPS means it is getting corrections but not yet rtk accuracy. GPS Single means it is receiving no corrections. The right arrow is a basic indicator based on color. Red is GPS Single, yellow DGPS, orange RTK Float, green is RTK Fix!
The problem is: I never used AgOpenGPS. I only know the code. Its called: lblFix.
I see. Off topic, but is there a need for more contributors on AOG? I have worked as a fullstack developer for a few years (mostly serverless stuff and AWS) but I work with farming now most of the time.
