I’m using RTKBase on raspberry, this is GUI version so it’s simply to configure.
RTKBase with the rtcm 1008 message is available!
Well, after update to 2.2.0 Trimble stoped work. It’s logging at base but CMR age is 0 sek. I tryed with different messages, antena descriptor, with/without TADJ parametr and everything is for nothing…
Strange,
If you connect a tool like rtknavi to your rtcm stream, is it ok?
example with my own base:
btw: A spectra receiver which was not working with RTKBase 2.1.1 was tested successfully this morning with RTKBase 2.2.0
Yeah, from rtknavi it seem to be OK but it’s not.
As I said, I tried different messages, antena named, parameter etc etc, and still nothing. May it be “Antena Delta Type” ? In my case is E/N/U, maybe it should be x/y/z?
I’m thinking and really don’t know what goes wrong. Below screen from my commercial base. There is only couple of messages, but there is 4094, which is:
Cytat Assigned to: Trimble Navigation Ltd.
The content and format of this message is defined by its owner.
Maybe that’s the point?
I don’t know your Linux command line skills, but this is what I would try:
- inside
rtkbase/run_cast.sh, delete-i "${receiver_info}" -a "${antenna_info}"on line 45 and/or 50 - Restart the base or relaunch the service, then test this stream.
If it fail, restart your tests with a working RTKBase 2.1.1, check that it works with your trimble, then compil and install rtklib 2.4.3 b34. You can use these lines to help you:
sudo systemctl stop str2str_tcp.service
sudo apt-get install -y git build-essential bc dos2unix
cd ~
wget -qO - https://github.com/tomojitakasu/RTKLIB/archive/v2.4.3-b34.tar.gz | tar -xvz
make --directory=RTKLIB-2.4.3-b34/app/consapp/str2str/gcc
sudo make --directory=RTKLIB-2.4.3-b34/app/consapp/str2str/gcc install
make --directory=RTKLIB-2.4.3-b34/app/consapp/rtkrcv/gcc
sudo make --directory=RTKLIB-2.4.3-b34/app/consapp/rtkrcv/gcc install
make --directory=RTKLIB-2.4.3-b34/app/consapp/convbin/gcc
sudo make --directory=RTKLIB-2.4.3-b34/app/consapp/convbin/gcc install
Now you have RTKBase 2.1.1 with rtklib 2.4.3 b34. If it doesn’t work, there is a bug in rtklib.
OK, I was trying couple of ways to figure out what is going on. My conclusion:
It work without deleting anything in program, BUT, antena descrition need to be ADVNULLANTENNA, only with this phrase it works.
I’ve removed “-i” parametr from script and it work as well as with this parametr.
So, for Trimble antena descritor need to be ADVNULLANTENNA, in otherwise it won’t work.
Thanks for help
I’m glad it works!
Now I have to decide if I set the default antenna descriptor value to ADVNULLANTENNA for the next release. I’m not sure it’s a good idea to change this only for a specific brand because what would we have to do if another brand need a different value … ![]()
I had an absolute whale of a time today trying to set up a stream for a Trimble FMX. I’m writing these instructions because I couldn’t find a single clear source anywhere on the internet for using the RTKLIB strsvr to insert a correct 1008 message. So here goes:
Set your input and output streams in strsvr. In my case input was a COM port and output was NTRIP server to a remote caster.
On the output row, press the button in the ‘conv’ column to bring up the conversion options screen. Here, check the ‘conversion from’ box and select RTCM3 in the 2 drop-downs. In the message types box, type the messages that you already have, as well as any additional messages. If your base station is working at 1hz then the number in brackets should be 1, which is the time interval in seconds. In this case I have written all my usual messages, plus 1008.
1005(1), 1008(1), 1074(1), 1077(1), 1084(1), 1087(1), 1094(1), 1097(1), 1124(1), 1127(1), 1230(1), 4072(1)
Exit the window and then go to the main options for strsvr, the button in the middle at the bottom.
Check the ‘station ID’ box
Input the precise co-ordinates inn lat/lon/height format. I used 8 decimal places.
Make sure the offset fields are all 0
In ‘Antenna Info’ input ADVNULLANTENNA
You can leave everything else blank.
Hit OK, then start.
Your Trimble rover should now accept a correction stream from your F9P using only standard, free software and hardware.
So, did you replaced the antenna + receiver from your FMX set-up to F9P antenna+receiver ?
No, standard FMX receiver and antenna. All that was changed on the FMX was to change ntrip settings from the old service to mine.
Ok, so you have your how stream from an F9P and used it to an FMX setup!
I’m not sure what you mean?
I’m using the F9P to provide an RTK correction signal, not actual position data.
Did you mean “your own stream”? I believe it is so, except that F9P itself is not able to inject RTCM1008 but RTKLIB does that.
thanks to everyone in this thread/openag and RTKonnect. I can confirm that RTKbase will work with Trimble 372.
ZED-F9P → RTKbase → RTK2go → Lefebure NTRIP client(android phone) → RTKonnect(bluetooth) → Trimble 372
372 firmware 8.3
RTKbase version 2.2.0
survey/post process base accurate to 3mm
**Note: the 372 takes about 10 minutes to calculate RTK. you will only have DGPS until then.
Couple of comparisons to our setup. First off congrats on getting it to work, it’s a great feeling when you see that Rtk fix hit! Do you have your xfill setup? If you set it up it will give you 20 mins if you loose connection to base. Second thought is we set our port C in and out to 38400, pretty sure rtk2go broadcasts at 38400 and that might save you some cell data. It should get you Rtk in about 3-5 mins but I have never actually timed it so maybe it’s longer. I don’t know what version of rtkonnect you have but ours will do what lefebure is doing so you could eliminate the lefebure part of equation, ours goes cell hotspot to rtkonnect plugged directly into 372. Rtkonnect is the ntrip client. Again congrats, if you have any questions I can help you with let me know
was looking at the xfill in the settings and was wondering how that would work, when reading on the trimble site about it they started talking about a annual subscription for it, so i wasnt sure if it would work or not
Once you have Rtk lock for a certain amount of time it will give you 20 mins of xfill if you lose that Rtk fix. You need to set it up to come on when Rtk lost,also a çouple yeàrs ago they changed the baud rate and frequency but if you Google xfill you will find settings for it. I highly recommend it because if you lose cell service for a bit you don’t want to have to wait for Rtk to reconnect. Also did you set your Rtk time out to 240 seconds. I think it’s factory set at 60 seconds
I must have misunderstood something. Why would it take 10 minutes for the 372 to obtain RTK fix? It should not take more than a couple of seconds from the point of receiving all necessary correction messages.
Interesting that Trimble is here so open that it allows RTK correction data from the Android phone when almost anything else is locked to Trimble products. This is very good.
