Internet connection problem
When i want to set IP it doesn’t say undefined network on the tablet network setting, it says internet cable not connected, has anyone had a similar case?
Check if both ends of the cable are crimped propertly and colors(wires) are in same order. I once made same mistake… next to check is if the teensy is well connected with board with those 6 ethernet pins…
Also the board must be powered in order to establish the connection with agio…
During this time, I already found a mistake, it was these 6 pins on teensy, they are too short.
Thanks anyway
