hello everyone, let me introduce myself i am new to this forum, because i also switched to agOpen gps, i bought an almost ready-made set via rtk-gps.nl and got excited about this via Jaap (the owner)
I have a tree nursery in the south of the Netherlands, and I mainly want to use the GPS for planting and harvesting activities, where the driving speed is approximately 100 meters per hour.
on the advice of Jaap I have now purchased a system with 2 receivers and rtk and built it on our tractor (case 895 2wd)
the build is now over and now between the activities we can play with the settings
last year we tried to work with a Cerea system, but because of the low speeds it caused more problems than the desired result, in short, nice if you only do tillage, but if you have to go slower than 250-300 mtr / hour, Cerea fails.
previously we have always driven with trimble EZ-guide lightbar, but that takes one or two passes
what do we want to do with ag-open?
in the first instance planting, and then lifting, if we like that, I might want more options, such as when the tractor is at the headland that there is a signal to turn off the tractor, or to lift 3 points. I think I can make it as extensive as I want.
for now I hope to read many good ideas and tips here, and if anyone comes near breda or antwerp (belgium), leave a message the coffee is always ready here
greetings
Ruud mouws
