is it possible that the tablet connects usb automatically. have a usb hub with an rj45 and a usb. every time I start up the tablet I have connection problems with the USB hub. If I take it out and put it back in it works fine. you have to do this every time you start the tablet. asked me if this could also be done via windows that the usb could be reconnected automatically
Just found this amazing item on AliExpress. Check it out! C$18.11 30% Off | Baseus USB C to Ethernet Adapter Aluminum Gigabit USB C Adapter for Laptop MacBook Pro 1000/100Mbps USB Lan RJ45 Network Card
Get one of these and run everything on ethernet.
do not have a usb c connection on the pannesonic. only a usb3.0 connection. now need a usb to rj45 and a usb for radio. but have to unplug and reconnect the usbhub every time at startup otherwise it just won’t work. then you need a USB port for the radio module
i use a lr xbee radio with this module to usb. MiniUSB Carrier Board for XBee Plugins for XBee radios - ArduSimple
guessing it’s connected to the ardusimple board to get RTK corrections from your home station ? if so, for what purpose do you need to have the MiniUSB Carrier Board connected via usb to the tablet ?
no its connecting to the tablet. in agio i use serieal ntrip
so you must have it connected ok … it seems to me that the usb hub is a problem from what I understood you have a problem always when you turn on the tablet as if windows does not detect that a usb hub and some devices are connected to it…
Hello everybody
I have exactly the same trouble. Yesterday I couldn’t work because the tablet just found 1 COM port. (And at least me, I need 2: 1 for steer and 1 for GPS) I think it has more relaction with Windows 10 than with AGIO but I’m not sure.
When I press the “check port” botton, I doesn’t happen anything.
Probably the best way for a long term fix up is changing to UDP…
thats right
or is there a way to connect the radio to the board? then i dont need the usb
there is a solution for xbee to be plugged into the ardusimple board but I don’t know what the settings must be, as for the usb HUB maybe this video will be helpfull USB keeps disconnecting and reconnecting on Windows 10 PC Fix - YouTube
USB devices may stop functioning correctly when multiple devices connected to the same USB hub go into selective suspend - Pomoc techniczna firmy Microsoft
