Is it possible to use ArduSimple RTK3B budget? Inverted RX/TX
Hi, Is it possible to use Ardusimple RTK3B budget on 4.5 board version? I see now, that this model has RX and TX inverted on the left side of the board, not realy sure why they did that.
I bought this model, because it has Galileo HAS support, and based on a few tries it can achieve arround 11 cm accuracy without RTK which could also be useful for field work.
Thank you for your help.
Ok, i can now probably answer myself since i got some info from ardusimple:
Quote:
"Only the text is inverted, but the functionality is the same. In some boards we labelled “TX2” from GPS and in some others “RX2” from radio. All boards have an output pin on the same pin. All the boards have an input on the same pin.
We improved this labelling in our latest simpleRTK4 by using a double label."
So pinout is the same as on other boards.
Yesterday i tried with stationary antena and managed to achieve 5 cm accuracy using Galileo HAS. Realy impressive piece of technology.
