I’m getting ready to power on the system for the first time. I wired everything based on the diagrams I found in the wiki and in this forum.
I’m using a 24v motor with a converter. I am using a power distribution board which I am pulling power off of and grounding all components on (picture for reference). My converter is pulling 12v power from this board and the yellow wire is sending 24v to pin 18 on the pcb. Is it ok that I have connected both grounds from the converter to this board? Something doesn’t feel right about it but from the diagrams it looks like this is ok.
Yes. You can tie both grounds together. If you test them there is continuity between them.
ok good to hear thank you
