Issue All in one board V2.4 micro
Hi,
I using a All in one board Micro v2.4 in dual GPS setup. This was working fine for 1-2 years. But since one month i have the issue the the teensy don’t get data from the right f9p which gives position data. Both F9P can be checked via the ucenter via USB this works fine. With debugging of the teensys both f9p recognized but the data of the right one is missing.
I checked than usage only one f9p this is working quite fine. So every part is working quite fine but in dual combination the teensy don’t receive data from the right f9p, after debugging it was also shown that the left f9p data can be used.
Has anyone ever seen a same issue?
I also configure both f9p new with the ucenter software and also flashed the teensy new. But nothing helped.
Best regards
scholl
Try reflashing again using the configomatic app. It takes seconds to do.
It will also do the teensy for you aswell
Click on the latest release
