John Deere 6190R install
A JD install I did a couple of years ago with a HYD valve, motor setup doesn’t appeal to me.
Pics will be from start to finish.
Cleaning these out, as may need them
The valve
Bracket for valve
fitted
10 pipes coming out of the cab
took a bit of finding what went where but jacking the cab up helped
Went & got a few hoses made, & a few fittings
A few extenders should make life easier connecting hoses
hoses fitted to the valve
And a main shut off valve…which I have used once, but its there if needed, I’m the only driver really.
On to the wiring
Deere R cab has a nice cable entry spot in the floor
Can break out the little tabs as needed
plug fitted
and labeled
tablet mount, a motorbike handlebar mount off ebay, works well too
all labeled for later
Temp charging supply, fitted a direct line before completion
Made a bracket for the board supplied by @TeddyStamford
and fitted in the cab
Few more bits
Receiver mounted, or changed really, was a Trimble dome before
Led installed on the front pillar, it it’s lit the valve is live
And the switch controlling it
Steer switch fitted
Extending the cable from the 23 pin plug to make things easier
And labeled
Leaving it like this
It works
Onto the WAS, this proved to be a real pain, mostly for different reasons that I will cover later.
First attempt at mounting
Will come back to it later, back to the wiring
5 volt reducer fitted
And a few earths
fingers crossed
Let’s see if we have power
Yep
Centering the wheels
The WAS you installed is fine, but I recommend installing the sensor in the steering knuckle like the original. Everything’s hidden and you won’t accidentally break the WAS lever with your foot :stuck_out_tongue:
I’ve created complete kits that make this task easier - https://navisklep.pl/en/p/steering-sensor-in-steering-knuckle-set/
I’ve also included a technical drawing of how to turn the pin.
The most difficult part is drilling the hole in the tractor’s front axle.
What’s this for? The AIO has a built in 5v regulator to power the WAS already.
I didn’t know that.
Good to know for the next time.
Back to the WAS, tried this
too tight
tried a few other ideas
time to modify it a bit
Nope
Settled on this in the end, well what I thought was the end
Ethernet
Installed
steps back on
and a bit of paint
testing
Ran into a problem, steering wouldn’t kick out when grabbed, after a bit of advise from here I found out I needed the pressure sensor jumper
Whats with the blue wire you soldierd underneath? Youve already got the cytron to pin 18 wire soldierd
Nice install
The landrover WAS are good but a pig to install. The pencil type linear sensors are alot easier to install and possibly nearer.
Just going by the advice I was given at the time.
I tried the linear sensor too, but I couldn’t get it to return any voltage, maybe I got a dud, had the same with a landrover type too.
So got it going, spreading dung with a rear discharge spreader.
Only problem was the autosteer would randomly drop out, then once or twice it would just steer full left.
I played about with it for a while but things got busy & I just ran it as guidance, not a problem for me as had been running a gps for 25 years or so, Trimble 250 & a 150 before that.
Then in spring 25 had a bit of time to look at it, put the multimeter on it & the first problem was an intermittent earth, so earthed it to the chassis of the tractor, next was the sensor wasn’t working, had bought a pair off eBay so fitted the other one & it wasn’t working either.
Bought another off Amazon this time & it worked, so fitted it slightly differently
that worked but have since altered it again to this, main arm slightly longer & the bracket swivel on top rather than the front, can see the earth wire too.
working well now
Then the tractor was at the dealers & they had the cab off, when it came back it would go full left if I hit the steer switch, thought they maybe had wired it back up wrong.
So started checking things out & found this on the WAS cable
That will have been my earth problem also, dealer had wired everything up perfectly as they found it.
Put another steer switch in while I was in there, as the green one is often under the palm of my hand.
That’s the end of this install, maybe it has helped someone, as a picture speaks a thousand words.
I’ll be back looking advice in a couple of weeks when I start the next one… :rofl:
Great documentation!
Next time, you can try another tractor with the UM982, TM171.
