Looks, like your BNO085 is detected well during Start up!!
If your bno is connected directly to your nano v3 steering board (What your Kaupoi 4.1 PCB Configuration is) there is no indication on the IMU Symbol. BNO data is transfered via Steering board.
Load your vehicel data.
In older versions I had the problem with nano V3/ IMU Setup. No roll until machine data are loaded once, after powering up.
Did you check running it via usb, in this case you also have to selected COM Port to your steering PCB. (IMU port is not requíred)
Hi Folks!
Thanks for your response and comments! @wland - you are absolutely right. The IMU symbol does not get green but it is working after GPS is working.
But now an additional question: how can I change the axis setup for the roll axis for the IMU?
I could only find the possibility in the setup to switch the direction for the case that rolling to the right is negativ.
