Keya not working on simulation mode
I’ve collected everything for my setup and now I want to test everything before integrating in the tractor.
My setup :
  • AIO 4.5 Standard
  • F9P and its antenna
  • Teensy 4.1 with ethernet
  • 4G/Wifi Tp Link router
  • AA-ROT-120 WAS
  • BNO085 adafruit
  • Keya V4 with deutsch connector
I tested everything before connecting the keya and everything is working. Pcb is connected to router and I connect my FZ G1 to the corresponding wifi network. Imu is working, as well as steering angle sensor. For the teensy program, i choose the “KEYA motorwheel” in aog configomatic.
As everything was working, I connected the keya motor and powered everything.
In simulation mode, I made my guidance lines and activated autosteer… and no reaction from the KEYA.
Is there something I’m doing wrong ?
Also I’ve seen videos on facebook of people testing their keya by moving their WAS ( WAS not simulated but AOG still in simulation mode), can it be related to that ?
I’m no electronics pro but in simulation mode, as I tell AOG to follow a AB line, KEYA motor should be moving… Here nothing is happening. Cables are connected rightly.
I don’t really get what I’m doing wrong.
Thank you for your help,
Have you engaged pwm drive mode in steer settings
Yes I think I did it correctly, it is my first time with keya so i’m not sure where to start to configure it correctly
Just fit it and go through the steer wizzard, they are very reliable motors and work out of the box
