Latest version not retaining applied area
I closed Ag open gps and when I re opened the field my applied area was gone, I’m also using agshare if that could be the issue
That happened to me as well last week. I think it’s an Agshare issue? My directory is on OneDrive, so I was able to restore a previous version that had the application data. I turned downloading from Agshare off so it only pulls files from the local directory.
Yes I did this as well, hopefully I can figure out how to get the old file back
Do you have Cloud Load enabled in AgShare options?
Yes I did I turned it off and made a test field and didn’t lose the application area, sadly my rear field appears to be lost
Will be fixed in next patch! Issue has been found and fixed
