Logging of dog weed spraying machine
Hello all, I have a sprayer which can see dock weed with cameras, and then spray it spot by spot. The sprayer is equipped with 6 cameras each running on a Raspberry Pi. Then there is a 7th Raspberry Pi which contacts the tablet of the operating terminal. They connect to each other via Bluetooth. In total the machine has 82 nozzles/solenoids.
Rumbojet
Now I would like to register in Agopengps where and when the machine sprays. I don’t need to control the machine or anything like that. I just want to register when and where the machine sprays. My idea is to feed the signal from the control of the nozzle back to Agopengps. Is it true that Agopengps can visualize a maximum of 60 sections? Or can this also be 82?
I am currently using a Nano via USB, what do you guys recommend?
Thanks, Hains
