Looking for some help withe AIO4.5 STD
Trying to get going with a couple of AIO V4.5 boards and I don’t see 5V VIN to the teensy. I have 12V at all the test points and only 5v at the WAS test point. All other 5v test points have no voltage. I installed the latest v4 firmware using the teensyLoader without issue. V12 power is connected to pin 22 and ground to pin 23 at the ampseal. Appreciate someone getting me going in the right direction.
You are missing the voltage regulators for the GNSS and Teensy.
Ah, Thank you sir!
