Unfortunetely it is’nt working. I’m using it with AP SectionControlNet, so it gets an IP on both sides. It looks as it working well, but I don’t receive any commands from AOG, that means no relays are switched. The opposite direction is working well, all sectional switches will be indicated correctly. But as I wrote above only this way is working. I drove in the real field, started spraying nothing works.
Did you set the corrct ip in AgIO?
Check with ipconfig and maybe the 3rd number is wrong. Change in AgIO udp setting and press send.
Maybe helps
Greetings
You can check the incoming bytes in the webinterface or with the serial monitor.
Use 192.168.1.1 or 192.168.1.77 to get it. Activate the debugmode, connect the esp with usb to see the debuginfo
I’m using it with AP SectionControlNet, so it creates 192.168.1.1 for ESP and 192.168.1.2 for AGIO:
See the following response, from serial monitor and debuginfos. I was able to use the webinterface via 192.168.1.1 to activate debugging and saving it.
In Simulator mode I get all switches in Manuall, but in automatic it’s seems all running but no data will receive from AOG.
Aog Version is 5.6.2 - My setup was working well in previous version V5.2.
There is something wrong with AGO or AgIO: it doesn’t send the needed info. You may check this with wireshark. AgIO should send to 192.168.1.255.
Try another AOG version, please.
which board do you use for the ESP32 section control?
Ali Express has a 8 Channel ESP32 WIFI Bluetooth BLE Relay Module. Would that work with your code? What is the maximum amount of sections you board supports?
