I’m switching to the latest AOG and installed the latest .ino if they were needed or not. The D2 pin is High no matter what I try. Anyone know what the cause could be?
If you are using the Ethernet shield it pulls d2 high.
that explains it. Thanks
The ethernet shield doesn’t need pin d2. If you put stacking headers on a nano and mount the shield on the nano with the shield pin d2 cut off it will work.
COOL. Will do!
