Micro Vs Standard PCB Pros/Cons?
Hi, I’m in the process of ordering a V4.5 AIO pcb and I’m not sure if I should go with the Micro or Standard board. I built them both out on JLCPCB and the standard is roughly $30 cheaper so that’s the way I’m leaning but want to make sure I’m not compromising performance by going with the standard over the micro. What are the main differences besides size?
From experience of the 2 sizes the standard pcb fits down beside the seat alot better than the micro.
The f9p is easier to configure in the standard size as you just plug a usb to it. The micro f9p needs inserted into the pcb then needs an additional 12v to power it up to configure it.
