Vili
November 11, 2020, 4:41pm
#1
I am planning to use these momentary switches for the workswitch and the steerswitch.
These are the same buttons that my tractor uses.
[https://www.mouser.es/datasheet/2/418/1/NG_CD_2329388_1-1316949.pdf ]
With the steerswitch there is no problem because I can change it through the interface, but I would need the code to convert the workswitch into an toggle button.
I have no idea of programming, so any help is welcome
hello
even if it is not the same switch you can find a switch on 12 mm diametrer with on off position
it looks more easy to avoid to change the soft …
RS 111-6515
Vili
November 11, 2020, 5:29pm
#3
thanks, but I would like to use the same type of button with orange led.
this is an other one more similar by the look
RS 226-047 ref IPR1SAD3L0S Marker APEM
after it is not easy to find one with the correct color but if he can share same ole and design …
