Motor rotates in one direction
Is a motor without reducer good for me?
I can find a car wiper motor around me. Would it benefit me if I cut the reducer part and use it?
You can find Phidgets motor in europe :
https://www.eztronics.nl/
https://www.autosteer.cc/ (Andreas site)
I use this from aliexpress
12V 5,2K Rate
It took a month to arrive.
Thank you for your suggestion. I ordered the engine in the picture I found in my country. not in the values ​​you give, but I think it will do my job. 700 RPM 40 w
PCB circuit box is finished. I used a 12 pin car socket. the cable is also ready. If I stick a strong magnet on the bottom of the box, will it damage the circuit elements? I’m going to mount it to the tractor with a magnet.
Where did you found the motor you mentioned in Turkey? Did you try it?
I am also looking to get a motor in Turkey.
Kormas motor 50mm çap 750 RPV
