Moving from one Tractor to Another
I have a couple of tractors setup with AOG and has been working great. I was having some issues with a board that was loosing communication with the on board GPS. So I grabbed a PCB from another tractor and swapped it out with the problem PCB. I thought I would just restart AOG and it would push the correct info to the board on startup. However I noticed that the wheels were not pointing right on screen so I think it was still using the info from the other tractor since zero was different on the other tractor. I ended up just going through the wizard again quick just to get going at the time. Is there a proper procedure that I should be taking when moving components from one tractor to another? Currently on version 6.7 if that makes a difference. Thanks.
When you load a Tractor/machine profile in the Configuration menu it should send the parameters to the Teensy.
I have noticed this as well. I have two tractors and the wheel angle for sure doesn’t seem to transfer with saved settings. Also the IMU offset doesn’t seem to load with the respective tractors. Have you noticed that also?
