Hi all, I want to import all my fields from my PC management software via a KML file and I have exported every fields under 1 KML file. Will AOG work with this or do I have to export each field as it’s own KML file?
When I open the file on Google earth it comes up as each field is it’s own entity with a name and an area attached to each field. But then my thinking is will AOG recognise this and create separate fields or is the whole farm going to be under 1 field name with lots of boundaries and data attached in one file?
