New Build, Checking requirements
Hi All,
I have been doing a lot of reading of the forums, and am planning on building a autosteer system. Before jumping in I just want to check that my understanding is correct for the hardware that I will need. I am thinking that I need
  • Tablet
  • PCB (plan on getting one pre made, diyfarmtech)
  • GPS (Simple RTK2B - basic starter kit)
  • Wheel angle sensor (landcover height sensor)
  • 24v DC motor for (fidgets)
I can stream NTRIP corrections from a local CORS station. I also plan to 3D print steering cogs & a case for the PCB.
Am I correct in this list of hardware?
Thanks in advance :slight_smile:
Walt
Sounds about right… You’ll need a 12-24 v converter, as the cytron will only put out 12v
Thanks, I have ordered the parts :slight_smile:
Thanks for the help, I have made put the system together and now it is in the tractor working :slight_smile: couldn’t have done it with our the forums
