Please reply with model number then year/series.
Hello
NewHolland T6030
Iām looking for a steering mount for:
T5120 autocommand
T6020
TS115
Can anyone help me with this?
Hi
Has anyone any luck finding a steering mount for the new holland tractors I have a
T6.155
Ts115
Many thanks
Here is my version of motor bracket for New Holland T8000 or TG series tractors. There is some borrowed design parts from French colleagues and I donāt consider this as perfect.
I did mine with PETG, no cooling, very hot nozzle (250oC), do not recommend TPU for gears as it is starting to squeak after heavy usage. Motor is Robotech 437rpm (Robotshop.eu) for max torque and optimal speed, maintaining comfortable to steer without disengaging. Use small, hardened pin (2mm welding electrode) and drill a hole in a metal shaft of motor to achieve long lasting result. Glue is not enough.
Updated in 2025 JAN, for robust lever.
Link for 3d STL files and sample pictures:
Hello, do you guys already tried some STL files for New Holland T6? I found a few STL files on forums but maybe you can send me the best one for New Holland T6 (T6070)?
Thanks in advance!
Can you please share some images here as I cannot view them on the Cerea forum. Many thanks
Any pictures on where best to mount the motor holder on a new holland t6 t7 tsa range
Anyone got anything on new holland tsa t6 or t7⦠cant find a decent fixing point and too much plastic
My 1st bracket i made off the steering column was crap so took the advice and pulled the steering wheel off and the plastic trim to find some really decent fixing point.
I used 2 clamps which were 55mm to 59mm, 1 for the steering column and 1 for the phidgets motor. Cut some 4mm steel plate and half mooned the 1 end and welded to each clamp.
There is alot of height adjustable room on both the steering column and motor so lining them up was easy.
Iāve decided to mount the motor the top side to stop you banging you legs on the motor and to keep it out of the way. It hasnt obstructed the instrument cluster at all.
Will need to cut a small slit in the plastic trim at the rear approx 4mm to allow the plate to come through
By using the height adjustable cap on the steering its easy to undo the cap and lift the steering wheel completely away from the gear sets when not using the autosteer for long periods of time and road use. Ive used the relay mod for the autosteer disengage.
Heres some pictures so far
I 3d printed a mount that fits over the existing plastic and it works fine, based upon Potato Farmerās universal mount. The only problem is that I made the mount by using photogrammetry to scan my T6ās steering column and so it wasnāt entirely accurate. Some judicious work with a rasp and some sandpaper made it all fit, but I probably canāt really share the file as it needs so much work after printing.
One of these days Iāll try and scan the actual resulting motor mount. But it might give you an idea how I went about it - I wanted to do something non-destructive.
Hi
@EdwardC do you arledy have steering mount to New Holland?
Looking steering mount for the same tractor or tracrtor that has same plastics?
Yes I need to New Holland t7060, t6030 and tm155
I used file from another forum and modified for my own needs(TM_Halterung_für_Universal_Motorhalterung - cerea-forum.de) (TM_Lenkrad - cerea-forum.de). Dm if u canāt get these files.
Anyone have any steering mounts for phidgits motor for NH Genesis? 8x70 series
Unfortunately Iāve not had time to take the mount off the tractor and scan it. I only have the original file that I printed, which needed a bit of filing to make it fit. Iām happy to share that with you if it would help, but you will need to make adjustments to make it fit.
Edit: Here is a link to what I printed on Thingiverse (before being adjusted with a file)
New Holland motor mount bracket (pre-filing)
Itās not problem to adjustment to tractor, I only need somethink to mount steering.
Iāve edited my post above with the link - I had to wait 24 hours to publish it as I only just signed up to thingiverse!
