After I connect the lan cable and turn on udp in agio, i cannot connect anything due to the fact that i have no com ports available. Any guesses on why this is and how can I fix it? Thank you!
Is teensy led blinking fast? If not than you may have wrong firmware flashed
Also when using udp you dont need to look for com ports, they are for usb serial communication only
Yes, it is blinking fast, I just cannot connect anything to my laptop trough the lan cable, only trough usb.
Have you been through this guide
It works now, thank you very much!
