No gps data in agopengps v6.8.1
Hi all, recently upgraded to a new tablet and installed version 6.8.1 to it and the teensy. In AgIo UDP monitor I am receiving gps data but agopengps is not acknowledging it, so continues with the rotating “no gps” icon.
Had this system working on an older version different tablet but not now and I don’t think I’ve missed anything! Any help? Tia
Have you configured the ethernet settings on your new tablet
Yes as far as I’m aware they’re all correct as I can connect to the board and agIO detects it all, just not data transferred into agopengps, not even IMU data
Put a picture up of the agio page
Do you have the 3 green modules all showing connected
I will do later. Yes all 3 modules showing green and connected, data in the monitor screen in agility, I know usually there’s a little delay in agopengps when everything boots up but currently it never comes on
Does antenna have a clear view of the sky
Yes mounted on tractor roof at time of testing
A silly question but your not pressing the redX when the agio page loads up are you which then shuts down the connections.
Seems odd you get all 3 green modules connecting but no gps
Maybe put some picture up
This is what I’m getting at the moment
Click on the speech bubble at the top
Is the teensy flashing orange light
Yes got orange light on the teensy. I’ve had a new teensy arrive today so might try that
Looks like right messages
Have you tried re installing that version or possibly trying an earlier one.
Its also showing your connected to rtk but the gps bar is still red.
Currently trying to download a different version now, thanks!
Does the software version in the tablet need to match that in the teensy at all times? So each version I try do I need to flash the teensy again?
No that shouldn’t matter.
Have you accepted the prompt you get for running aog and agio to allow access
Success with version 6.2! I’ll go with this for now and try and investigate the root cause to the problem with 6.8.1. Thanks so much for your help
I believe the very latest release needs a 64 bit operating system maybe your tablet doesn’t support that ?
Try the one before the latest release like 6.7.2.
Something tells me there was a bug in the 6.2 version but it maybe on the section control side
Hey there, were you ever able to figure a solution for this issue? I just finished installing in my tractor today and tried to configure and im stuck at tne same place you were. Green lights across the agIO screen but no connection to the gps. Im using an agopen.shop control box and antenna.
Edit: no success using an older version, however now i notice from your pic that i am not even getting a gps fix in the agIO screen in the upper left corner. still reading 0.00 on both lat and long. so now im not sure were my issue is.
So for some reason it did not like being connected to the hotspot via my tablet and my base station BEFORE it was connected to the control box. Working excellent now after connecting to the box first, then hotspot, then rtk. Not sure if that was OP’s issue but it was my fix.
I had the same issue, installing an old version did not work at first, then i noticed agio used the same profile i made with the newer version. After making a new profile (while everything was still connected) it suddenly worked
Hi, sorry for slow response. the older sw version seemed to fix it for me, and since im not the one using GPS (built it for my brother) ive actually forgot about this issue and never looked futher into a root cause. Sorry i cant be of any more help
